I have recently bought my new smartphone " Redmi Note 7 ".
The issue am facing here is that am not able to sync my data with the Redmi note 7 smartphone.
The fitbit app is not able to find the tracker at all..
Is it because it's not supported with the smartphone yet ? If so when can we expect the support or is there any way to workaround this issue and make it work with my Redmi note 7 pro ?
I am using a Charge 3 tracker .
Thanks
Best AnswerI found this app at Google play store and installed it ... Working good....https://play.google.com/store/apps/details?id=com.abhijitvalluri.android.fitnotifications
Best AnswerHi @AhmedELHOOT it's not on the list of compatible devices - click to see the list
Sometimes a device not on the list still works sometimes, but you can't count on it for all features all the time. Sorry.
Best AnswerThanks I found a solution for it on Google play store..
Thank you
Best AnswerWonderful @AhmedELHOOT thanks for the update.
Best AnswerYou welcome
Best Answerho acquistato fitbit charge 3 e ho un xiaomi redmi 7..cofermi che funziona perfettamente come compatibiltà..grazie
l ho appena acquistato e non vorrei fare il reso
grazie
