09-14-2019 20:49
09-14-2019 20:49
I have recently bought my new smartphone " Redmi Note 7 ".
The issue am facing here is that am not able to sync my data with the Redmi note 7 smartphone.
The fitbit app is not able to find the tracker at all..
Is it because it's not supported with the smartphone yet ? If so when can we expect the support or is there any way to workaround this issue and make it work with my Redmi note 7 pro ?
I am using a Charge 3 tracker .
Thanks
Best Answer09-26-2019 06:10
09-26-2019 06:10
I found this app at Google play store and installed it ... Working good....https://play.google.com/store/apps/details?id=com.abhijitvalluri.android.fitnotifications
Best Answer09-14-2019 20:54
09-14-2019 20:54
Hi @AhmedELHOOT it's not on the list of compatible devices - click to see the list
Sometimes a device not on the list still works sometimes, but you can't count on it for all features all the time. Sorry.
Best Answer09-16-2019 18:47
09-16-2019 18:47
Thanks I found a solution for it on Google play store..
Thank you
Best Answer09-16-2019 18:52
09-16-2019 18:52
Wonderful @AhmedELHOOT thanks for the update.
Best Answer09-16-2019 18:59
09-16-2019 18:59
You welcome
Best Answer09-24-2019 23:57
09-24-2019 23:57
hi Ahmed
I have redmi 7 and I cannot connect my Fitbit alta hr to it can you please post the solution.
09-26-2019 06:10
09-26-2019 06:10
Best Answer07-09-2020 02:27
07-09-2020 02:27
ho acquistato fitbit charge 3 e ho un xiaomi redmi 7..cofermi che funziona perfettamente come compatibiltà..grazie
l ho appena acquistato e non vorrei fare il reso
grazie
