06-14-2016 12:56
06-14-2016 12:56
Best Answer06-18-2016 14:59
06-18-2016 14:59
First thing the Surge can not be setup through the Phones Bluetooth screen.
Is the Surge still connected to yourFitbit account, i hope it has not been disconnected, since then it will need to be reconnected to your account, so that the app can then do the paing of the phone and Blaze.
Normally by forcing a sync will pair up the devices again.
Best Answer06-18-2016 22:09
06-18-2016 22:09
Best Answer07-30-2016 12:22
07-30-2016 12:22
Hi there @JR_McG, welcome aboard to our Community. I see @Rich_Laue have provided you great help.
If this is the case that your tracker does not show on your account, is require to paired again in order to sync. So if the issue still persist, please take a look at the following link https://youtu.be/eNbozxFz3oA for instructions to set up your tracker.
However in this case you have already an account so you need to set up using your account, keep in mind the following steps:
In case the tracker is not recognized, verify Power Saving Mode is off. This mode frequently causes the device to disable Bluetooth.
Keep me updated how it goes I'll be around.
