11-08-2016 11:31
11-08-2016 11:31
Best Answer11-08-2016 14:06
11-08-2016 14:06
Hi
Feel free to check out the Fitbit Article regarding not being able to sync the tracker.
https://help.fitbit.com/articles/en_US/Help_article/1866
Hope it helps
11-08-2016 16:53
11-08-2016 16:53
Best Answer11-09-2016 00:48
11-09-2016 00:48
11-11-2016 11:32
11-11-2016 11:32
@harshdeep12 @NotSoMerry I recommend restarting the tracker and also checking out the suggested help article @SunsetRunner shared above for an extended list of troubleshooting steps. Let me know if that helps.
Best Answer11-11-2016 11:40
11-11-2016 11:40
11-11-2016 11:49
11-11-2016 11:49
@NotSoMerry Thank you for confirming that the phone update and phone restart resolved the syncing issue. I appreciate you taking the time to share what worked for you so others experiencing the same symptoms can give that a try as well. Thanks again for checking back in.
