09-04-2017 06:19
09-04-2017 06:19
Hi,
For several days now, I have problems syncing my charge 2 with my Galaxy S4 Mini.
It is realy frustrating! My fitbit started out as a nice gadget, but now I begin to see the problems it also gives.
I already read all the tips in this community. I logged of my Bluetooth. I restarted my phone....
Do I need a dongel to reconnect with my laptop? Wouldn't that be easier?
Best Answer09-05-2017 09:21 - edited 09-05-2017 09:21
Hello, hello, @katiave! It is nice to have you here.
Just a quick question, have you also tried to restart your tracker?
Just wondering, since you didn't mention, so if you haven't you can do it a few times in a row. This usually solved syncing issues.
Keep me updated, I'll be waiting for your updates. :}
09-05-2017 12:36
09-05-2017 12:36
Hi Solange,
I restarted my phone and my fitbit, and for now it seems to work.
Hopefully it wil keep working 🙂
I see you are a moderator. Can I ask you an other question?
I see several people are having problems with the sleep stages, including me.
Is someone working on that problem? Can we expect an update?
Thanks for your help
Kind regards
