11-07-2020 20:13
11-07-2020 20:13
My aria2 scale will show my weight but when it gets to the body fat percentage, it just says "---%".
I have tried several things, restarting, removing batteries, changing batteries, measuring several consecutive times, making sure latest firmware is installed, etc, etc.
I am reading this is a very common issue in the Aria 2, had Fitbit come with a solution?
11-07-2020 20:20
11-07-2020 20:20
There is a setting whether or not to show body fat % in the phone app; maybe you have that turned off.
Profile pic > Aria 2 > Users > you >Display Bodyfat (%)
Best Answer11-07-2020 20:25
11-07-2020 20:25
Thank you JohnnyRow for your reply.
yes, absolutely I have checked that ad well, it is set to active and I have even try to set to Disable and then enable again, and then take several measurements, still shows nothing.
I researched significantly and this seems to really be a big issue with the Aria 2 and appears Fitbit does not really care or does not provide support. Anyone has managed to make it work?
11-09-2020 11:42
11-09-2020 11:42
Hi, I have the same issue however I can’t work out where it says display body fat as per Johnny Rows’s comment.
Best Answer11-09-2020 13:00
11-09-2020 13:00
Under Aria 2 / People using this scale / select user / enable display Body fat %
Best Answer11-21-2020 19:55
11-21-2020 19:55
I ended with same problem. No one responding on it..lost trust
