09-21-2019
06:22
04:25
JuanJoFitbit
09-21-2019
06:22
04:25
JuanJoFitbit
The manual states if two users have similar weight, you should be able select icon to allow correct identification. The aria2 seems to always default to one icon without any option to direct to correct icon, apart from a manual reassign in the fitbit dashboard. I am missing something, or is this unit faulty?
@TheSpaceMan welcome to our Fitbit Community! I'm happy to assist you with your Aria 2 since it's not allowing you to select your icon.
I'd like you to follow the steps that are listed in this help article which explains how to select the icon and have your Aria 2 to assign your weight ins to your user properly.
Let me know how it goes! 😀
