03-04-2019
15:14
14:53
03-04-2019
15:14
14:53
I just synced my Aria after a battery change and now my body fat percentage went from 27.8% to 42.1%. My weight measure of 198 lbs is the same after the sync. Has anyone experienced a similar issue and is there a fix for it? Thank you.
03-05-2019 03:35
03-05-2019 03:35
@AlienNJ Welcome to our Fitbit Community! I'm sorry to hear that your Aria scale is not providing accurate body fat readings after replacing the batteries.
I'd like you to re=calibrate your scale by taking out the batteries for 15 seconds and put them back in. Once you've done this, weigh yourself 5 times in a row and see if your body fat readings are accurate again.
Keep me posted on the outcome!
