12-13-2017
20:34
14:53
12-13-2017
20:34
14:53
Have they ever released or fixe the issue with the Aria not being able to connect to wifi on routers running 802.11n, because the Aria only being able to connect to the 802.11b networks is to put it bluntly f***ing ignorant especially since most the routers with the higher speeds now have to run on one of the other protocols. I just upgraded and now this scale is completely useless. Fitbits technology is just becoming trash with the fact they haven't adopted anything since releasing it and fail to adequately maintain updates on it so everything is compatible.
@Crissie2389 It's great to see you in our Fitbit Community! So sorry to hear that your Aria scale is experiencing syncing issues due to a WiFi ERR message. I would like to follow up and would like to know if your Aria is still unable to connect with your WiFi or if the issue got fixed since I'll be happy to follow up and help you accordingly.
@SteveH Thank you very much for your help my friend!
Catch you both later! ![]()
Following this thread . . . .my Aria stopped synching when we got a new router, and doesn't want to let me reset to my new router. Following the directions, I can get it to the point of showing the Aria network on my phone or tablet, but the Aria network won't connect because - wait for it - it still tries to find the old network and password. So I seem to be stuck in the endless loop of trying to get it to completely reset and it simply won't.
@RuthinSC Thanks for joining us in this thread and welcome aboard @dphebus! I noticed that you both mentioned that you have new networks. Please check out this post from @SunsetRunner since it contains great troubleshooting steps that will help you to get this issue resolved.
Keep me posted on the outcome my friend! ![]()
Best AnswerJuan, no it is not. First, you want me to follow a 26-step process? Start by telling me in detail how to set up a guest network on my router. Mrgunn's 26-step process is complicated and I am not technologically savvy.
I can get my Aria to the setup active mode. Now what? I can get into the process on my phone and the Aria network shows up, but when I try to use it, it says not connected to internet. Again, it thinks it is connected to my OLD network, and isn't looking for the new one? HOW DO I RESET THE NETWORK?
Best AnswerGo to fitbit scale setup and follow the steps, www.fitbit.com/scale/setup/start. Also.....I'm not sure if this will help with everyone's issue, but it's worth mentioning. I received this advice from another fitbit member. I have the Aria. The Aria does not recognize the newer 5G networks. I have a new wifi network and I couldn't get my Aria to switch from the old network to the new. I kept getting the error message...could not connect. My wifi has the option of 5G or 2G and I was using 5G. The Aria would not connect using 5G. It was recommended that I switch to 2G. When I switched, it connected immediately. After the process was complete, I went back to my 5G and everything works.
Best AnswerI have been trying for hours. I just tried switching to 2.4 and it didn't work either. My scale is only a year old. Why should I have to pay another $100 for a new one???
Thanks for the post. I tried switching to the 2.4 g and also changing the protocol to th 802.11 g/n as suggested but neither worked. Still get the Wifi Err message. Fitbit needs to develop a patch to correct this problem with the Aria.
Thanks Julie! I had tried this while using the online chat with customer support a few days ago but it crashed my network and I gave up. I thought I would give it another try after reading your post, and it actually worked this time!!! I know I have run the setup at least 50 times since we changed our router. I'm glad it finally worked. Thanks again!
01-12-2019
12:17
08:15
JuanJoFitbit
01-12-2019
12:17
08:15
JuanJoFitbit
Yes, I was on the phone with fitbit "support" also for this issue. no 802.11b anymore. but my ipad 1st generations also only run on 2.4gbit speed connection and they work on xfinity's latest router just fine. fitbit "support" told me to log into to network gateway and look for 80211b but I only have 802.11g/n and 802.11n. so fitbit "support" hung up on me. 3 times. 4th time just said hey you had a few good years with the scale what are you complaining about. I said I wouldn't have purchased the scale if the wifi wasn't gonna work in a few years.
They said ha ha we stole your money for a device that was obsolete ha ha you are sol and we don't care ha ha ha.
Who on earth purchases a scale they can only use for 2 years? had I known I would never have purchased the stupid thing. what a rip of from the "front-runner" of tracking devices. What a scam!
Why the he** would I buy a second scale when the first one only worked for 2 years. trash. a complete rip off and the company couldn't care less.
Because Fitbit couldn't care less that they stole our money for a junk product and now they want you to spend another $100 for what? another year? who buys a $100 scale in the first place - i did - joke on me - and they really think we are going to fall for it again and let them steal another $100 from us. No way fitbit scammers.
not true doesn't work because fitbit cannot understand modern technology wifi
Moderator edit: merged reply
I’ve been trying for weeks to connect my original aria to new router. Today I got to what I thought was the end but no, I’m stuck at the final step with the error message. What a waste of money these scales are. I can’t acford to upgrade to the newer scales and these won’t even come out of set up mode! I’ve not been able to sync since October but could at least weigh myself, now even that is impossible
Dont understand the complex fixes, how do I change to 2G? If I ever get these working, which I doubt will happen, the battery will be flat after the amount of time I’ve had to spend trying to connect. Theory of the Fitbit range was good but fails to achieve its intentions. Very disappointed 😞
@beccah7 I'm sorry for the late response. I'm also sorry about the experience you had with your Aria scale since it's no longer under warranty. I know how frustrating this is for you. I appreciate your feedback and comments since this helps us to keep improving.
@Toddi1 Welcome to our Fitbit Community! I'm also for the late response too. However, I'd like to follow up on and would like to know if the issue persists or if your Aria could connect to your network.
See you later!
@RuthinSC I'm sorry to hear that you decided to throw away your Aria scale. Your feedback is greatly appreciated.
@Toddi1 I'm sorry about the hard time that the Aria scale experienced. However, I'm glad to hear that you managed to resolve the issue. Please don't hesitate to get back if you need further assistance with it.
Best AnswerTook batteries out and replaced with new ones had a greeting come up for a minute and then said tap to change and before I could tap the screen went black and has not come back on. Could use some help on what to do to get it to work .
Thank you,
Carri
