09-29-2019
02:36
06:05
JuanJoFitbit
09-29-2019
02:36
06:05
JuanJoFitbit
My Aria suddenly seems to be eating through batteries. I have had to change them very frequently over the last six months and at the most recent battery change (two weeks ago) they Aria now won’t sync and a message came up today saying the batteries were dead. How is that possible?? I have read through the other comments related to this and it seems to be a fairly common issue... Fitbit do you have any advice?
Moderator edit: updated label
09-29-2019 11:20
09-29-2019 11:20
Same problem. Batteries lasted about 30 hours.
10-07-2019 09:05
10-07-2019 09:05
I too have the same problem. Any fix for this?
Best Answer10-16-2019 09:38
10-16-2019 09:38
Me too!!! is Fitbit Going to Help with this????
Best Answer10-16-2019 14:40
10-16-2019 14:40
Ditto. About two months ago I started noticing the same issue on my Aria version 1. New batteries last about two weeks max. Must have been some change that happened in a software update that is waking up the device and draining the batteries. Hope they update it. Otherwise this scale just became useless.
Best Answer10-16-2019 14:57
10-16-2019 14:57
Recommend that you call Fitbit and explain your situation. Phone number is on their website.
They are sending me a new scale. Haven't received it yet but expect it any day.
Good luck.
10-28-2019 02:58
10-28-2019 02:58
Hi, I have the same problem two weeks of battery life max. Now I'm taking the batteries out after every measurement what is ridiculous but so far the only solution.
Best Answer10-28-2019 07:16
10-28-2019 07:16
Best Answer10-30-2019 07:45
10-30-2019 07:45
How did you contact them?
