11-07-2015
04:54
14:53
11-07-2015
04:54
14:53
Hi, I have a question on whether it is really possible I'm made up of 33% body fat (according to the aria scale). Here are my stats:
51 year old woman
5' 6"
132 lbs.
currently wearing a size 6
33% body fat according to the charts means I'm obese. I don't feel obese. I know I need to lose 8 more lbs. to be at my ideal weight that I feel best at, but this 33% body fat has been pretty consistent the whole time I've been dieting. Even after I lose 8 more lbs., I do not think it will be much less than 33% body fat on the aria scale. I'm definitely not lean, so I know selecting the "lean" category in the settings would not apply to me.
I'm fine with just ignoring this and feeling good about the lbs. I've already lost, but every morning it's still a little depressing to weigh yourself and think how is it possible that 33% of my body is pure fat.
I weigh myself bare foot, dry feet every morning before I shower. I do not move the scale. It is sitting on the floor in my bedroom, same spot as always.
02-19-2018 07:21
02-19-2018 07:21
Same here, 5’ 4” and 143 pounds, says i’m 35.9%. I’ve been doing a new weight lifting routine for over a month. I’ve lost almost two inches off my waist, only lost 4 pounds because I am building muscle and the scale still says 35.9%. This can’t be right.
02-19-2018 14:05
02-19-2018 14:05
It sounds very accurate to me quite honestly.. We tend to think we're leaner than we are.. My wife is 5'6 140 pounds weighing less than you, and very fit and she sits at about 35% body fat.. If you're a female and have extra fat around your body you are most likely over 30% that is just the truth of the matter.. Women carry way more fat then men.. What you have is healthy I wouldn't worry..
02-19-2018 14:23
02-19-2018 14:23
02-19-2018
17:59
05:09
JuanJoFitbit
02-19-2018
17:59
05:09
JuanJoFitbit
My children have been professionally measured.?they are 21 and 23 % body fat yet the got bit measures them both at 35% ?? Not a good product.
Both my children were measured at the doctors and they were 21 and 23 % body fat yet the Fitbit measures them both at 35% ridiculous it’s a useless product!
It also measures my children who are in their early 20% ... professionally measured at 35%. The product is not accurate. Way off
Sent from my iPhone
Moderator edit: merged reply
02-19-2018 18:15
02-19-2018 18:15
02-20-2018 08:21
02-20-2018 08:21
It's really odd I guess it depends on who uses it or the scale.. My wife and I are both NASM certified trainers and she runs her own camp gladiatior camp and for some strange reasons our aria measures us both similar to dunk and calliper methods.. Oh well.. So by your estimations since I'm 6% body fat according to aria I'm either 0% or 12%? Okay... I know it's not perfect but it's not as far off as some people tend to think.. The common occurrence I see on this forum is how everyone thinks there body fat is less than what the aria tells them which seems odd.. Once again, my personal opinion is that people don't want the truth for the most part..
02-20-2018 14:54
02-20-2018 14:54
johneric8,
It would be fine for me if the scale was just 5 or 10% off and consistent. I think for many the scale works but there are many in the thread that have a similar issue. Depending on when I moved and had to rejoin my scale to a new wifi, it jumps all over the place. Either I am 18%, 34% or 24% body fat on the same scale, the only change has been me moving the scale and connecting to a new wifi.
I am willing to accept the truth, I just don't know which one to believe.
02-26-2018 10:44
02-26-2018 10:44
Hi everyone! I really appreciate your feedback and comments about the accuracy of the body fat percentage on the Aria scale. I'd like you guys to check out this help article, under the subject "How can I get the most accurate reading on my Fitbit Scale?" If you see that your Aria scales are being inaccurate, please get in touch with our Support team.
@johneric8 Thanks a lot for your help and contribution in this thread.
I'll be around if more assistance is needed my friends!
03-14-2018 14:56
03-14-2018 14:56
Done that. Nothing works (I’ve tried everything over 2 years) other than ignoring BF measurement which is clearly totally inaccurate in so many cases. A shame they can’t just fix it for us.
03-15-2018 06:13
03-15-2018 06:13
@LottieD Thanks for joining us in our Fitbit Community! I want to follow up and would like to know what troubleshooting steps have you tried before getting in touch with our Support team. This information will help me to determine the cause of the issue.
See you later my friend!
03-15-2018 07:01
03-15-2018 07:01
03-15-2018 16:22
03-15-2018 16:22
03-15-2018 18:22
03-15-2018 18:22
03-16-2018 00:29
03-16-2018 00:29
03-17-2018 16:18
03-17-2018 16:18
04-10-2018 06:07
04-10-2018 06:07
@kyash9916 Thanks for getting back! I was able to get in touch with our Support team in regards to your case and was told that they'll contact you via email in order to follow up and provide a solution. Please keep an eye on your email account.
@LottieD @LoriBee Thank you both for taking the time to try the recommended workarounds. Since the issue persists after following the troubleshooting steps, I'll send your case to our Support team so they can find a solution for you guys. You should receive an email from them soon.
@Susan56horse I would like to follow up and would like to know if your Aria is showing your body fat accurately now or does the issue persist?
See you all later!
04-10-2018 06:39
04-10-2018 06:39
04-10-2018 09:03
04-10-2018 09:03
So in contacting support, the best case is they send a new scale?... and I am assuming the new scales have a solution this issue?
I have always thought the % was correct until the few months when I have measured elsewhere and learned more about the %... there is no way you can swap 10lbs of fat for 10lbs of muscle and stay at a 30% fat with a normal bmi. Luckily I didn't give much stock to the % before as I wasn't knowledgeable enough, but I wonder how many people gave up on their fitness journeys after no progress on their scale?
04-10-2018 17:57
04-10-2018 17:57
@dali137 wrote:So in contacting support, the best case is they send a new scale?... and I am assuming the new scales have a solution this issue?
The issue with my scale didn't really change my fitness journey. I am assuming at least that it is accurately reflecting any changes regardless how far off the measurements is.
But I have to wonder what the future of Fitbit is given I can not find scales that do similar measurements for around $40 Singapore dollars (around US$30) and wristbands even cheaper. I just moved so will try to Fitbit scale again to see what reading it is giving me this time. It has jumped around a lot everytime I have moved. But if it still seems to malfunction, I will probably try a different brand scale given the price differences now
04-10-2018 21:30
04-10-2018 21:30
