12-29-2023 10:07
12-29-2023 10:07
Aria does not recognise me and keeps calling me a guest can anyone please help, I used to be able to do it with old app but now I’m completely lost 😞
01-02-2024 22:43
01-02-2024 22:43
Hi everyone,
I'm writing today to share a workaround I discovered that helped my wife (and hopefully you!) reconnect with our Aria scale after it stopped recognizing her. This might apply if you've experienced similar problems, where the scale used to identify you but now just registers you as a guest.
Backstory:
For context, my wife was happily using the Aria in August 2023 until she went through a weight change during her pregnancy. Soon after, the scale started mistaking her for a guest on every weigh-in. Back then, assigning past guest entries to users was simple, a feature sadly missing now. Frustrated, I put on my thinking hat and found a solution that worked for us.
The Issue:
Your Aria scale no longer recognizes you as a user, despite previously working flawlessly.
Assumptions:
Workaround Fix:
Why it works:
The Aria uses your Fitbit app as a data source to estimate who's stepping on the scale. It seems to apply a reasonable range around your recent weights (maybe ± 3 lbs, but the exact formula is unknown). If a weigh-in falls outside this range, it flags it as a guest.
Before, assigning guest entries helped mitigate this and was easy, however, based on all the threads/posts this feature is no longer working. By manually syncing your recent weight with the app, you essentially "prime" the Aria's memory, making it more likely to recognize you on the next try.
Pro-tip: This fix might not work instantly for everyone. If it doesn't recognize you the first time, repeat steps 1-3 a couple more times. Hopefully, it should click soon!
Remember, this is just a workaround until a more permanent fix is available (if ever, since this is a legacy product). However, it helped us reconnect with our Aria, and I hope it does the same for you!
Feel free to comment below if you have any questions or have a different experience with this issue. We're all in this together!
Best,
Determined Husband
01-02-2024 22:43
01-02-2024 22:43
Hi everyone,
Backstory:
The Issue:
Assumptions:
Workaround Fix:
Why it works:
Best,
Determined Husband
01-03-2024 03:51
01-03-2024 03:51
@3picD Thank you for discovering and sharing your workaround. I moved this thread to the Aria forum, a better fit. I hope it will help other Aria (original) users with this same problem.
Laurie | Maryland, USA
01-03-2024 04:49
01-03-2024 04:49
My Aria is doing the same thing FWIW. I've tried doing what is being suggested below but so far haven't had any luck 😭.
Will keep you posted if I'm able to figure it out.
01-03-2024 06:17
01-03-2024 06:17
Ok I will try that, thank you for sharing with us 😘
01-04-2024 12:36 - edited 01-04-2024 12:42
Sue -
Here's a link to what allowed me to get my FitBit Aria scale to recognize me again. It's a bit of a hack but got the scale to compute my BMI again!!! I had gained a few pounds since the scale last recognized me so the trick was to get within the 8lb. limit since my history showed it knew who I was. I was able to tell the weight to try and match by looking at the last time the app logged my BMI in the history.
This link should point to my reply (I hope!). You might have to scroll down a bit to find my entry. If you have trouble, let me know.
https://community.fitbit.com/t5/Aria-Scales/Aria-2-won-t-register-guest-weight/m-p/5525899#
It would be really nice if FitBit/Google would provide a way to reset the weight setting to use a brand new sample for an existing user.
Anyhow, good luck with your scale and fitness journey. 😉
01-05-2024 05:58
01-05-2024 05:58
hi thanks for your reply but I’m a bit of a techno phobic and that looks really complicated to me but thank you 🙏
01-05-2024 06:06
01-05-2024 06:06
You're welcome @Swampiesue...
I agree. It's too bad the App doesn't make it easy to reset user data.
Thanks for the vote. You can message me here if you are interested in additional guidance.
-Steve
01-05-2024 06:07
01-05-2024 06:07
Thank you very much 🙏🙏🙏
01-05-2024 06:11
01-05-2024 06:11
You're welcome @Swampiesue @🙏
01-08-2024 02:22
01-08-2024 02:22
Great work around, thanks! My son and I weight approx. the same so sometimes we are mixed up, without the possibility to choose the correct symbol. It proofs that the fatpercentage is not measured but made up, because his % is 16 (20 year old man) and mine is 35 (middleaged woman). If it was actually measured, it would be easy to distinguish us.
01-14-2024 01:36
01-14-2024 01:36
Tried this last week and unfortunately didn't work for me, very frustrating
