12-16-2021 18:42
12-16-2021 18:42
Hi!
In the Fitbit portal, we can assign the Weight to different users under:
Dashboard -> Devices -> Aria - Aria 2 -> Measurement
However, only Measurements for the previous 1 month is shown. Do anyone know if we can do assignment of Weight for period older than 1 month?
12-17-2021 06:32
12-17-2021 06:32
@HopefulGuy I'm sorry, but you can't reassign weights that are more than one month old. The same limit exists in the mobile app. If you want to put in the effort, you can make a paper record of the incorrect assignments, delete the weights in the weight log, then manually log the correct weight to the correct user. If I had this issue, I would just delete the incorrect weights from the weight log and call it good.
Laurie | Maryland
