10-08-2019
22:08
06:14
JuanJoFitbit
10-08-2019
22:08
06:14
JuanJoFitbit
I have been using an advanced biometric scale with my Fitbit that records my weight, BMI, etc. for a couple years now. I suspect it is made by the same manufacturer as the Aria. I have heard that my scale called # RETROFIT can be used with the Fitbit programs and that there exists an APP that makes it work seamlessly together. Does anyone know the file the program is named and where I can download it? Thanks, Bob
Both programs, RETROFIT AND FITBIT may sych as before, but I don't know for sure.
I too want to sync my Retrofit scale to another app but can’t figure out how to do it. When I go to Fitbit app it asks for the model of the scale and I don’t know. Any help would be appreciated. Thank you.
Best AnswerI too have the retrofit scale and it did/ does sync with Fitbit after you connect the scale to retrofit app. I am no longer in the retrofit program and would love to figure out how to connect it to Samsung health or my fitness or any other app but cant figure out how to pair it. Is it now just a paper weight?
Best AnswerAll you need to do is download the Fitbit App. You can just use the Fitbit program like you did with the Retrofit program as they are nearly the same. Good luck.
Best AnswerI just put new batteries in my retrofit scale Ian’s it doesnt work. Do you think it may be that I’m not longer a retrofit customer?
Best AnswerI too want to sync my Retrofit scale to another app but can’t figure out how to do it. When I go to Fitbit app it asks for the model of the scale and I don’t know. Any help would be appreciated. Thank you.
Best AnswerSame here! Says I lost 20 pounds in the past two weeks! I did give up soda, but even I know I didn’t lose that much lol. Very disappointed.
