I know the title is quite broad but my scale just does not work.
I followed all of the steps on how to set up my aria air scale but here are the problems:
- when I step on my scale it shows a random set of numbers ranging from 1 to 80 kilos before going back to 0 and giving me no result. I have recalibrated the scale several times but this keeps happening.
- when the scale did give me a number it was ridiculously high or low, at a given time weighing me 8.6 kilos.
- the scale also does not register my weight on my app.
Can someone please help me with this???
Hi,
I still havent found a solution. I'll let you know if I do.
Best AnswerI'm having similar problems. My new Aria Air won't sync with my phone or laptop and displays a weight (no BMI) that is significantly different than my older Aria scale and the another scale I have in another room (both of those other readings are the same btw). Haven't found anything elsewhere that would prove helpful.
