05-28-2022 00:14
05-28-2022 00:14
Hiya,
My partner recently purchased the Fitbit Aria Air scales as our old scales were giving inconsistent weight readings.
However, I have weighed myself this morning and I weigh 163 pounds, which to Fitbit is apparently 11 stone 9 pounds, however, when I googled it, apparently 163 pounds is 11 stone 6 pounds. Which is correct, and if Fitbit IS giving me the incorrect reading, why?!
05-28-2022 05:36
05-28-2022 05:36
Hello @TeganC123 and welcome to the Community. You are correct that 163 pounds is 11 stone 9 pounds. Look again at your google weight converter. When I do that, it says 11.6 stone, not 11 stone 6 pounds. The button on the back of the Aria Air lets you change the display units on the scale. The scale displays stone and pounds. I verified this with my weight, toggling between stone, pounds, and kg.
Laurie | Maryland
05-28-2022 05:36
05-28-2022 05:36
Laurie | Maryland
