02-24-2019
00:57
14:53
02-24-2019
00:57
14:53
Hi folks,
Seen several similar issues here but no solution has worked to date, wondering if anyone has any more ideas?
been using the Aria 1 daily for years without issue. Recently though me and another user have been dieting, so weights have changed; and now recognised me as Guest, and other user either as Guest or as me (despite there being a significant difference)
we can manually reassign the weights through the dashboard, and that’s what we now do daily. However, obviously want it to recognise properly. Based on previous posts we have :-
manually updated profiles on dashboard, and then weighed 3 times;
done the same taking the batteries out for 15 seconds then doing the same;
weighing and manually allocated 25 times in a row;
reset and gone through initial setup again;
cleaned all surfaces and repeated
...but to no avail. I know we could delete all accounts and start from scratch, but there’s many years of data there that I do want to keep
Anything else I should be trying?
thanks,
Sandy
02-24-2019 09:34
02-24-2019 09:34
When the wrong initials appear on the scale, tap hard on the lower right corner until the correct initials appear.
02-25-2019 07:36
02-25-2019 07:36
@SandyJM Welcome to our Fitbit Community! I'm sorry to hear that your Aria scale keeps recognizing your user as "Guest" even though you have tried the recommended troubleshooting steps.
I would like to follow up and would like you to know if the issue persists or if the issue got resolved after trying the advice that shared my friend @SunsetRunner, which is also a recommended step in order to reassign your weights to your user.
Looking forward to your response! ![]()
Best Answer02-25-2019 16:05
02-25-2019 16:05
Sadly no. It’s not wrong initials, it just says GUEST; and no amount of pressing, stamping or jumping changes that.
Official response from from support email suggests repeating weighing and manual allocation for 5 days. We’ve been doing that for weeks, but will do it for 5 days again and report back
02-26-2019 03:39
02-26-2019 03:39
@SandyJM Thank you for getting back and trying all the recommended troubleshooting steps. I was able to get in touch with our Support team and was told that they were handling your case via email. Since the issue persists, please reply to their last email and they will be happy to follow up and provide a solution.
Don't hesitate to get back if you need further assistance! ![]()
Best Answer01-26-2020 11:45
01-26-2020 11:45
My scale is showing the wrong initials and I tried tapping on the lower right corner and nothing happened. Is there something else I can do
Best Answer01-27-2020 07:05
01-27-2020 07:05
I have fitbit Aria 2 and same problem with recognising GUEST. I wish you answered to the previous message on the community board for everyone to learn!
02-02-2020
06:07
04:23
JuanJoFitbit
02-02-2020
06:07
04:23
JuanJoFitbit
I agree!
Sandy, can you tell us what happened? I'm having the same issue. Nothing is working. Seems like a lot of people have this issue. I don't understand why they don't put the answer out there for everyone to see! What did you have to do? Did it ever get fixed?
Moderator edit: merged reply
02-06-2021 08:51
02-06-2021 08:51
I have the same problem and have tried tapping but no luck. Have anyone been able to figure this out?
02-23-2021 16:22
02-23-2021 16:22
I have the same problem. It displays the other person's name in the family for me. For him it displays guest. I have corrected the names for the weights in the account, but it keeps doing the same thing all the time. It does not learn the weights of the individual people so as to display the correct name.
