01-02-2024 11:24
01-02-2024 11:24
Can anyone help me reset my aria 2 after pressing reset button please idiots guide as I’m not very technical thanks
01-07-2024 10:49
01-07-2024 10:49
That iPad may be why you're having issues and could have saved a lot of troubleshooting if it was mentioned earlier. Please try the setup again from a laptop.
one cruise ship at a time!
Best Answer01-07-2024 09:10
01-07-2024 09:10
All you need to do is take the batteries out of the scale and put them back in.
10:13
16:43
AndreaFitbit
01-07-2024
10:13
16:43
AndreaFitbit
I’ve done that but now I don’t know how to reset them, 🥲
I’ve got www.com/setup going along the top and when I weigh I’m still guest.
Best Answer01-07-2024 10:21
01-07-2024 10:21
You need to follow the instructions to a T on that website.
Best Answer01-07-2024 10:22
01-07-2024 10:22
If I go to website it wants to charge me 5 pounds a month
Best Answer01-07-2024 10:23
01-07-2024 10:23
Send me a screenshot of EXACTLY what you see.
Best Answer01-07-2024 10:25
01-07-2024 10:25
This is where you need to go: https://www.fitbit.com/scale/setup/start
Best Answer01-07-2024 10:48
01-07-2024 10:48
Hi I’ve tried to connect twice however it just keeps going back to the beginning again, my battery in my I pad is failing so I’ll try again when I have more power thanks for your help 🙏😘
Best Answer01-07-2024 10:49
01-07-2024 10:49
Best Answer01-08-2024 03:23
01-08-2024 03:23
No I’ve been trying for a week but despite the battery loss checked this morning and yesterdays try at fix seems to have worked, thank you so much 🙏🙏🙏😘😘😘
01-08-2024 18:07
01-08-2024 18:07
Not a problem, glad it's working!
