01-18-2019 12:33 - last edited on 09-10-2019 14:53 by MatthewFitbit
For assistance with setting up your Aria scale, please consult this post.
If your scale does not display "Setup Active" after removing and reinserting the batteries, it may have already been connected to a network. In order to return the scale to this mode and proceed with another setup process, you'll need Complete instructions for this process can be found in this help article, along with the instructional video below.
Putting your Aria into Setup Active mode
If your scale does not display "Setup Active" after following these instructions, please remove the batteries and try again - it may take a few tries to get the timing just right. Once your scale is showing this message, you can continue with the setup process as normal.
