01-14-2014
08:45
14:53
01-14-2014
08:45
14:53
I bought and set up my Aria about a week ago. I immeidately noticed that it was reporting my weight about 2-2.5lbs lower than my existing scale.
Doing an experiement, I placed a 25lb. dumbell on each scale getting 10 readings each. My old scale reported 25.0 -25.1 lbs each time. The Aria reported 23.1 - 23.3 lbs. each time. Since the dumbell is a known weight, to me the Aria is about 7% below what it should be.
I've read elsewhere on these forums about how an individual's weight can vary and how the Aria can report a variance of about 2lbs. In this case, I'm looking at a static weight in the dumbell.
While I can understand that I guess, what I have a problem with is consistent underreporting that I am seeing.
Has anyone else done this type of experiement or observed something similar?
Cheers
I recently got a FitBit Aria to augment my FitBit based weight loss target. I found most of this thread's comments about the inaccuracy of Aria is **ahem** accurate.
My old school mechanical scale (used in hospitals) shows 180 pounds while Aria tries to pleasure me by showing the same me (at the same time) as 176 LB. So, I have started showing my wife the Aria metrics while I secretly find myself at the same weight on my other Old School Scale. Thanks Aria for converting our wallets into the sources of an early electronic junk piles.
Aria scale "pleasures you"!? If that's true, suggest you use it for "pleasuring" yourself rather than for weight management, hehe, Otherwise, just add pounds you know are off. I use mine to track against calories in the Fitbiit app--so I don't have to log them manually each time then set weight loss target for 2-3 pounds more to account for inaccuracy.
Best AnswerDid you find anything better. I am at a point of just trashing mine but I don't want to end up down the same path with another brand!
Best AnswerActually, I started accepting(or living) it and continue to use it(like a good husband) 🙂
Regardless of if its relative(to the other manual scale with me)accurate or not, its accurate with itself.
In other words, if my real weight is 175 lb on my manual scale/hospitals scale, this cute lady Aria shows me 170lb(thats why I called her cute 😉 ). But it measures my weight daily correctly with that delta of 5 lbs. Thus, I continued to use this scale daily (wifi connected) with that Parallax Error. So, I dont trash it at this moment. 🙂
Best AnswerI compared my Aria weight to 2 other scales at home, and it was only 2 pounds lower, so I'm okay with that. 5 pounds is a lot! I stand straight and stare forward at the wall and move scale around to weigh 2-3 times. Fitbit app will report the average of every weight taken the same day.
Best AnswerHave you tried sitting on it bare **ahem**? If that doesn’t work.. see if you can shove it up your rectum.
Best response of the bunch!!! 😂
My scale randomly decided NOT to connect to MFP anymore or show up on WiFi even though it’s still talking to Fitbit. Go figure. I’m ready to shove it up someone else’s rectum since I’m not feeling too masochistic these days!!
Best AnswerWell, Matthew ... darlin ... I just went to a medical weight loss doctor AND dietician and YOUR scale keeps showing me at 44.3% and 44.7% body fat while their TWO THOUSAND DOLLAR equipment only shows me at 37.4%. So how do you explain THAT major error??? Do you realize that mistakes like these can cause people with body dysmorphia and eating disorders to have set backs??? So maybe think about THAT before you come back with your lame @$$ excuses as to why things don’t work right. At this point I can’t even get your stupid app to log my FOOD intake and I’m considering going with either Apple or Android and using the LoseIt app again. I PAY for premium service and get crap.
