The app weight graph has a vertical range from 0 to 22 stone. Since August my weight has fallen 12lbs to 11st 7lb. This fall is barely perceptible on the graph as the range is so great. It would have been much better if upper and lower levels could be set as defaults. On using the search here I see that in past years there are posts on this topic which show the graph with upper and lower set points. Why has this option been removed?
