08-08-2015 18:00 - last edited on 09-10-2019 14:53 by MatthewFitbit
I have been trying to set up my scales. I go through almost the whole process until its trying to connect to WIFI and then a "WIFI ERR" shows up on the scales. I have checked my settings on my modem and it is on WPA2 PSK. I have also reset the modem more then once and tried the set up various times with no sucess. Does this have something to do with my modem? I have never had so many issues trying to set up one of my devices and I am considering just returning your item as I didnt realise I would have so many issues (obviously I dont want to return it). Can anyone shed any light on this issue?
08-20-2016 19:29
08-20-2016 19:29
This is great info, and I think this is my problem. Thanks for the post, appreciated.
But my whole house is set up on WPA-2PSK. Televisions, Tablets, Phones, Printers on and on....now I have to drop password security to my whole house?
I dont think there is an excuse from FitBit for not having more "recent" wifi security protocals, because all/most the protocals were invented BEFORE the Aria. So Fitbit either went cheap with thier wifi device internal to Aria or below off these obvious protocals in the spec sheet.
Either way... the Aria goes back tomorrow. And unfotunately the two Fit Bit HR I bought and likely to go back too.....what a JOKE. Been on hold with help for over 35 min while I searched the discussion boards.
08-22-2016 07:25
08-22-2016 07:25
Hey guys @MCollins @urbane_cowboy @Xavier68 @ItsAusten @Wicked0wl @mschmitz @whatever1 @m_didus_falco @BFinPhoenix, hope you're doing great!
If you have tried what @SunsetRunner has shared here, but your Aria is still not connecting I'd recommend getting in touch with Customer Support directly so they can give you a hand on this.
Don't forget to mention the steps you've done so far to avoid getting the same ones. You'll be in good hands.
Have a nice start of the week!
08-22-2016 11:35
08-22-2016 11:35
08-23-2016 07:35
08-23-2016 07:35
Music to my ears @AaronPlant, I'm so glad to hear that after contacting Fitbit Support the issue was solved.
Hope to see you participating in the Community more often since I think it would be awesome for you to explore our Community, so you can go ahead and log to any of the topics that might be of your interest in our Discussion boards. Feel free to comment and contribute with your knowledge and experience.
I'm pretty sure this will help others!
Cheers up!
08-30-2016 21:06
08-30-2016 21:06
This is the problem when you get a new modem and it is assigned a password...... so my scale will never work. Perhaps Fitbit needs to warn consumrs and longterm users?
08-30-2016 23:51
08-30-2016 23:51
08-31-2016 01:23
08-31-2016 01:23
08-31-2016 19:36
08-31-2016 19:36
09-05-2016 05:53
09-05-2016 05:53
@TMacMeyer I would like to follow up on this and would like to know if the tips that my friend @whatever1 shared helped you to get the issue sorted out.
@BFinPhoenix I'm so glad to hear that you resolved the setup issue. Thanks for keeping the update posted here. I'd like to invite you to visit our "Discussions" board, where you can share your experiences, meet people and create new topics.
If more questions arise, let me know my friends!
09-17-2016 02:50 - last edited on 04-10-2021 06:11 by JuanJoFitbit
For the same reasons mine is headed to the bottom of my pool...absolute crap product...I got sicked in again with another poorly designed tech product from fitbit...never again.
Sorry man....if you want to build and sell a consumer product to average consumers dont expect them to then
1) Find a tech guy
2) PAy a tech guy...dont know whay you mean by service provider??? not sure about you but I simply went to a store bought a router plugged it in..set up the netowrk and it worked in 15 minutes,
3) Then change around a whole network to just connect your scales.
Why not tell people this on the box before they buy....
Another Fitbit disappointment...I got fooled for the second time with your products. There won't be a third time.
Thanks...I will fly all the way back to Singapore airport to return it.
Moderator edit: merged replies
09-19-2016 15:42
09-19-2016 15:42
Facing the same problem. Did you find a solution?
10-26-2016 04:23
10-26-2016 04:23
10-28-2016 07:05
10-28-2016 07:05
A much simpler solution worked for me... moving the scales physically closer to my router. They couldn't do the setup when in another area of the house (despite implying full signal strength), but were fine when in the same room. Once setup was complete I moved them back upstairs and syncing has been fine in the weeks since, it was just the initial setup that gave me trouble.
Well, it was all fine until we changed router, and then after a couple of days it randomly stopped being able to connect to the internet to sync, even though it was on wifi fine, but that's another story 🙂
11-23-2016 12:09
11-23-2016 12:09
Using only letters in the wifi name fixed my issue. I went one step further and put only letters in the password. I also only used a digit ssid. Previously i had my "<name>-2.4" and it would not connect. I kept the security level the same, just used a longer password that i had before. My password FWIW is 9 characters and it worked first after making changes.
11-23-2016 12:12 - edited 11-23-2016 12:12
12-16-2016 10:23 - edited 12-16-2016 10:24
Thank you! I was struggling with this bloody thing for ages and the only way it would work was if I disabled my wifi security when doing it via the website. No way I'm doing that (and nobody else should do that either, or use WEP, WEP is fundamentally flawed and is useless).
Using this tool it worked with a Wifi SSID with special characters and spaces and also worked with WPA2 PK straight away with no issues. This is the best solution.
12-17-2016 10:41
12-17-2016 10:41
How can this be the top voted answer?
This is not a coherent sentence:
"If you're getting this wifi err when setting up your scale, I would recommend which is the Protocol that your router uses."
As a consequence it doesn't solve anything.
12-17-2016 13:17
12-17-2016 13:17
12-18-2016 19:04 - last edited on 11-13-2020 20:00 by LiliyaFitbit
This wasn't the issue. I had to plug in an old router and use that.
Unfortunately the scale hasn't been very future proof.
Thanks,
12-25-2016 21:35
12-25-2016 21:35
My scale would not connect after changing the batteries. It had been working fine before the batteries died, so I knew it should still work fine. I contacted Fitbit support, and they walked me through setup, and then told me that the scale must have gone bad since it wouldn't connect with the WiFi Err message.
Since I didn't think it made sense that dead batteries would kill the scale, I spent some time playing with different settings to try to solve the problem. What finally worked for me was to force my wireless AP to use a specific channel. (I forced the AP to channel 11 for the 11N/B/G radio.) Adding this here in the hopes it helps someone else working to solve this aggrevating error.
Good luck!
