02-23-2016 19:08 - last edited on 04-06-2021 04:24 by JuanJoFitbit
Hi, earlier I was stuck in "sensing, thinking, err" so I reset the whole thing, reconnected to wifi and everything, and now I'm stuck with the message "Setup Active" scrolling across the Aria. It will not shut off. I took the battery out and left it for 15 minutes, put it in again, and it's still scrolling. If I leave it all night it's going to run the batteries down completely.
I had put this on someone else's post about the sensing, thinking, err but thought it should have its own since it's really a different issue. Thank you for the help.
04-15-2018 17:02
04-15-2018 17:02
I have been unable to connect the Aria scale to our home WiFi for the past 10 weeks. Went through the entire setup multiple times and restarted all devices in the hope that something might give.
After getting the WiFi Err message on the scale, it keeps going back to the SETUP ACTIVE mode. So now I have two issues:
1. Fitbit Aria won't connect to WiFi, making it an ordinary scale.
2. It won't quit SETUP ACTIVE mode, draining the batteries and keeping the light on.
I've sent the logs to support and hoping to get this resolved soon.
04-21-2018 09:01
04-21-2018 09:01
I have the same issue. Stuck in Setup Active.
04-21-2018 17:47
04-21-2018 17:47
05-01-2018 15:05
05-01-2018 15:05
Same issue. My Aria hasn;t connected in a month. Something is definitely wrong. Every time I try to set up over the past 4 years it's been getting sillier. I'm in IT and there is something wrong.
05-08-2018 22:05
05-08-2018 22:05
Me too!!!! Haven't gotten an upload since late March. Trying all sorts of avenues to get this scale working again. I made no changes to my network. Just one day it stopped working. I was able to get it to sync up again, but now zilch, nothing, nada. I am also an IT guru. I'm so irritated!!!
05-08-2018 22:53
05-08-2018 22:53
05-10-2018 07:25
05-10-2018 07:25
Hi everyone! I want to follow up on the setup and syncing issues you've experienced with your Aria scales. Please let me know if you get any error message during the setup process. Also, make sure that your routers run the protocol 802.11b and bandwidth 2.4GHz. If you guys need help with this information and you want to know how to run these settings, please get in touch with your Internet service provider.
Finally, let me know what is the make and model of your routers.
Looking forward to your responses guys!
05-11-2018 14:53 - last edited on 05-14-2018 07:20 by JuanJoFitbit
Ditto
No luck connecting Aria.
Moderator edit: format
05-14-2018 07:19
05-14-2018 07:19
@SunsetRunner Thanks for joining us in this thread! I'm sorry to hear that your Aria scale is not connecting with your network either. I want to follow up and find a solution for you. Please let me know if you have made changes to your network such as WiFi password, router or router settings. Also, let me know if you get any error message while you try to connect your scale. This information will help me to assist you accordingly.
See you later my friend!
05-14-2018 07:36
05-14-2018 07:36
05-16-2018 05:42
05-16-2018 05:42
@RazzleTom Thank you for getting back and providing the details requested previously! Please check out Kate's post where she shared a workaround for Comcast routers and an update about this issue.
Let me know if you have any questions!
05-17-2018 08:49
05-17-2018 08:49
Stuck in SETUP ACTIVE mode "hell" for 2 years. No changes to comcast that I'm aware of. Having issues with the watch syncing as well. Ready to ditch FITBIT all together. After reading all of these comments in this thread .... FITBIT has a problem that they cannot address !!!!
05-17-2018 09:14
05-17-2018 09:14
05-21-2018 05:24
05-21-2018 05:24
@Submariner Welcome to the Fitbit forums!. I'd like you also to check out Kate's post and follow the workaround that she shared, which is for Comcast routers specifically.
@RazzleTom If the workaround that Kate shared didn't fix the issue, our team is actively looking into this since Comcast updated their protocols recently. We don't have a timeline when a solution will be released. However, I truly appreciate your patience and understanding with this.
Let me know if you guys have any doubt!
05-26-2018 09:58
05-26-2018 09:58
Ditto.
Same dumb reply.
Remove battery 10 seconds.
If only it resolved these issues...
Mine is now cycling the same.
Set Up Active yet will not connect to wifi.
It worked perfectly fine prior.
Ridiculous heap of garbage now.
The words 'Customer Service' do not adhere to Fitbit. The lack is apparent all over the net!
Shameful.
05-27-2018 10:52
05-27-2018 10:52
I have Aria scale since 2014 I think... almost 4 years now and since november I think stop syncing... I move to another house and work fora month... now it’s been 9 weeks since last sync. Yesterday I follow every advice you gave but now it’s stuck in Setup Activated, can’t tour it offf. I remove the batery all night and still in setup activated. I’m from Chile (Southamerica) and don’t have customer service here.
05-27-2018 19:11
05-27-2018 19:11
05-28-2018 09:20
05-28-2018 09:20
@1Wendywoo It's great to see you in the Fitbit forums! I'm sorry to hear that your Aria scale has stopped connecting to your WiFi. I want to follow up on your case and would like to know if the issue persists or if your Aria keeps displaying the "Setup Active" message. In the meantime, try weighing yourself 5 times in a row and see if the message disappears.
@Coonsuelo It's great to see new faces in the Community. Welcome aboard! Please make sure that you follow the setup process as advised in the video that contains this help article. Also, make sure that your router runs the protocol 802.11b and the bandwidth is 2.4GHz. This information can be verified with your Internet service provider.
Keep me posted!
05-28-2018 16:12
05-28-2018 16:12
05-29-2018 09:13
05-29-2018 09:13
@1Wendywoo I'm glad to hear that the issue is now resolved! Thank you for letting me know.
I'd like to invite you to visit our Discussions board, in this board you'll be able to meet people, tell your stories and start your own topics.
Hope to see you in our Fitbit forums more often!
