03-31-2016
13:02
13:46
EmersonFitbit
03-31-2016
13:02
13:46
EmersonFitbit
To set the brightness setting (to auto, dim, normal, or max), push the left button on your fitbit which will show the clock. Then swipe to the left until you see 'settings'. Tap on 'settings' to open it, then swipe down until you see 'brightness'. Simply tap on the word auto and keep tapping to choose which brightness level you want (auto, dim, normal, or brightness). Mine was set to auto when i bought it today, but that was too dim for me so i changed it to max. It's perfect now (i am using the flare clock face which is darker but i need the date as well as the time digitally written out). The thing to remember though is that max will use more battery life then auto or dim settings. But i need it on max! Anyway, after finding no posts on how to change the brightness setting (it just said tap on it so i was tapping on the clock - then looking on my iphone through those settings until i finally discovered it right on the face of the fitbit but not on the clock face ...So thought i would share here so it will be easier for someone else
Moderator Edit: Format
03-31-2016 13:37
05-03-2016 07:03
05-03-2016 07:03
Great help the Blaze help shoud be more clear where the settings are I was looking in the app and windows.
05-06-2016 12:36
05-06-2016 12:36
Thank you so much! The dimness since the last update was making me crazy. I wish things like this were in the release notes.
08-22-2016 22:40
08-22-2016 22:40
Thx for the post Bulletproof77. It was very helpful!
10-28-2016 11:29
10-28-2016 11:29
Left button on my Blaze does not work unfortunately. Is there a way to adjust the brightness via the phone application?
10-28-2016 11:58 - edited 10-30-2016 03:31
Shure there is @bhavanisht on the Blaze swipe over to settings - tap the screen - swipe down to brightness - tap to adjust.
OK let's see if we can get the left button working
10-30-2016 04:25
10-30-2016 04:25
A warm welcome to the Community @bhavanisht and @Rich_Laue thanks for stopping by and the troubleshoot provided. I would like to know if the instructions provided by our friend here were helpful? If you keep experiencing inconveniences, do not hesitate in posting it.
See you around.
12-30-2016 07:52
12-30-2016 07:52
Thank you.
02-06-2017 16:57
02-06-2017 16:57
Thank you for your instructions. I did what you said and now I'm satisfied.
02-06-2017 17:10
02-06-2017 17:10
04-04-2017 19:35
04-04-2017 19:35
That does help
I would like a watch face option with thicker hands and chunkier hour markings, just to make it easier to read quckly
05-02-2017 05:34
05-02-2017 05:34
Thank you for sharing this information. My clock was too dim for me, now set on max and it is fine
05-02-2017 06:31 - edited 05-02-2017 06:38
05-02-2017 06:36
05-02-2017 06:36
05-07-2017 20:05
05-07-2017 20:05
Which face is that?
06-06-2017 16:54
06-06-2017 16:54
I dont see the option for brighrness,under settings on the app
06-06-2017 17:26
06-06-2017 17:26
You can do it on the device itself. Swipe left until the settings option comes up, tap on that, scroll down to the Brightness option and tap repeatedly until the option you want comes up (Auto, Dim, Max etc.)
07-07-2017 01:31
07-07-2017 01:31
Thank you I was doing the exact same thing looking on my IPhone.
07-15-2017 18:00
07-15-2017 18:00
Cool! Thanks for the info....
