03-31-2016
13:02
13:46
EmersonFitbit
03-31-2016
13:02
13:46
EmersonFitbit
To set the brightness setting (to auto, dim, normal, or max), push the left button on your fitbit which will show the clock. Then swipe to the left until you see 'settings'. Tap on 'settings' to open it, then swipe down until you see 'brightness'. Simply tap on the word auto and keep tapping to choose which brightness level you want (auto, dim, normal, or brightness). Mine was set to auto when i bought it today, but that was too dim for me so i changed it to max. It's perfect now (i am using the flare clock face which is darker but i need the date as well as the time digitally written out). The thing to remember though is that max will use more battery life then auto or dim settings. But i need it on max! Anyway, after finding no posts on how to change the brightness setting (it just said tap on it so i was tapping on the clock - then looking on my iphone through those settings until i finally discovered it right on the face of the fitbit but not on the clock face ...So thought i would share here so it will be easier for someone else
Moderator Edit: Format
07-16-2017 09:37
07-16-2017 09:37
Thanks for sharing. That was great and easy.
09-28-2017 03:05
09-28-2017 03:05
Thanks-nice and clear
09-28-2017 16:25
09-28-2017 16:25
You're VERY welcome 😊
09-28-2017 23:56
09-28-2017 23:56
05-18-2018 06:11
05-18-2018 06:11
My blaze suddenly went very dim and I could barely see the display. I went to the settings, shut down, which turns it off , I waited about a minute and turned it back in. This seems to be working for me- as of now the display is back to the original brightness like when I first purchased it.
05-18-2018 07:56 - edited 05-18-2018 08:04
05-18-2018 08:03 - edited 05-18-2018 08:04
Usually when you first purchase, it is on auto brightness (there is also a max) - see my post if u need to change it to a different brightness setting (there is auto, dim, normal, and max)
From Bulletproof (not sure why it says Recovery Runner)
05-28-2018 05:18
05-28-2018 05:18
I am unable to even see my screen at all to get onto settings! So frustrating! I want my screen so i can see it cant see anything! Please help, have followed guidelines above but as i cannot see anything on screen as it is so dark there's nothing i can do at the moment. Thanks
05-29-2018 02:53
05-29-2018 02:53
10-16-2018 08:58
10-16-2018 08:58
Thanks so much for posting, I must have looked on the app half a dozen times thinking I'd missed it!!!
10-16-2018 12:03
10-16-2018 12:03
