01-24-2018 03:25
01-24-2018 03:25
Hey guys,
So i just bought the Blaze yesterday, and i am trying to charge it but all the screen says is "fitbit.com/setup" I can't set it up cause the charge is too low. anyone have any idea why this is happening? I have plugged it into a computer USB and also into a wall charger, i have held the buttons down to try and reset and it wont do anything. thank you
Jennifer
Best Answer01-24-2018 03:27
01-24-2018 03:27
Yeah this happened to me too, just keep it plugged in and wait, it looks like nothing is happening but eventually it’ll start
Best Answer01-24-2018 03:30
01-24-2018 03:30
Thank you! that's what i thought, just cause the battery is so low, might just need to sit. Did you plug it into a computer or wall charger?
01-24-2018 03:30
Best Answer01-24-2018 03:33
01-24-2018 03:33
I plugged mine into the computer. It’s kind of annoying cause it doesn’t give any indication of what’s going on but just give it a while 🙂
Best Answer01-24-2018 03:35
01-24-2018 03:35
yeah it is annoying for sure, just shows the setup screen. I will plug it in and check it in a few hours, thanks for your help!=)
