04-04-2018
09:52
04:44
AlejandraFitbit
04-04-2018
09:52
04:44
AlejandraFitbit
Fitbit Blaze is not registering heart rate and battery is draining at an alarming rate! Took it off the charger around 10:00 am and now at 12:48 pm I am getting low battery warnings. Unbelievable! I have only used this for 18 months!
Please clean the contacts
http://help.fitbit.com/articles/en_US/Help_article/My-tracker-s-battery-isn-t-charging/?q=not+chargi...
Then Do a Restart
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
Also See this thread for charging best practices. If you are not charging it correctly you could be damaging the battery
https://community.fitbit.com/t5/Charge/Fitbit-charge-battery-problems/m-p/1323307#M53291
http://help.fitbit.com/articles/en_US/Help_article/1799
If that does not help contact support
http://help.fitbit.com/?cu=1
Wendy | CA | Moto G6 Android
I’m convinced this is a software issue, the same exact thing started happening to me on Saturday: battery draining, sleep insights not tracking when they were before, no heart rate monitoring. And I bought mine under 2 years ago. They have offered me a 25% discount, but I think I’m going to ride this out because they seem to correct themselves over time. I have a Flex I bought 5 years ago and while the battery is up and down, it seems to be okay now for some weird reason. (Shrugs)
04:51
05:51
04-05-2018
04:51
05:51
A warm welcome to the Community @DMcNorrill, @Ahencher, @lenperalta great to see you here and @WendyB thanks for stopping by.
I appreciate your efforts in trying to fix the battery and heart rate issues you are experiencing with your trackers. Regarding the battery, I recommend taking a look and follow the instructions provided in this post and for the heart rate at this one.
About the 25% discount, you can use that to purchase any Fitbit tracker (except the new ones). In this page, you will be able to compare them all and maybe there is one that might like you besides the Blaze.
Let me know the outcome. ![]()
Best AnswerThank you for the information. I have followed the instructions to clean the Fitbit, used a toothbrush/toothpick to scrape away all the "gunk" it has accumulated. I then put it back on the charger (plugged into the wall, not a computer) and let it fully charge. I then wore it for 3 hours, even turning off all notifications, syncing, you name it. It still died. This started happening out of nowhere. I have had it since December 2016 and haven't had any battery issues at all.
I tried everything and still no heart rate reading. I charged last night in a regular household socket. It was dead within 2 hours. Try charging this morning with a USB charger, looked like everything was fine. I took it off the charger and put it on my wrist within about 45 minutes I get an alert on my phone that my Blaze battery is low and a few minutes later, itsi dead again!
Best AnswerThis is more than frustrating. I turned off a bunch of stuff and that seemed to help battery life, but I turned stuff back on and the charge only lasts 5 hours. No wonder blaze is not being pushed and the more expensive Iconic is. Blaze only lasts less than 24 months. Sad!
