03-07-2018
20:08
03:19
AlejandraFitbit
03-07-2018
20:08
03:19
AlejandraFitbit
Just recently my Blaze has being dying after a day or two of use and I have noticed that the green lights on the back won’t turn off. I was curious if anyone has had these issues? If so, how did you solve it?
Best Answer03-07-2018 20:14
03-07-2018 20:14
Also, my app shows that my Fitbit has a full charge all the time, even when it is almost dead
Best Answer03-08-2018 03:21
03-08-2018 03:21
A warm welcome to the Community @Laceyrobinson84.
If you are having issues with your Blaze battery life, I recommend taking a look at this post and follow the instructions provided there. About the heart rate sensor, do you have this option on? If you do, I recommend swiping to settings from your tracker and change this to "Auto" or "Off".
I hope this helps, let me know the outcome. ![]()
