03-03-2017 05:57
03-03-2017 05:57
Anyone experienced fitbit blaze battery charging slowly mine take so long to charge fully
Best Answer03-03-2017 06:24
03-03-2017 06:24
How long? I got my low battery warning late last night and plugged mine in this morning while getting ready for work. From low battery to full took about 1 1/2 hours I'd say (give or take).
Best Answer03-03-2017 11:40
03-03-2017 11:40
Welcome to the Community @hollyhock and @daveowen! Your Fitbit Blaze should charge between 1 hour or 2 to be fully charged. I would like you to make sure you're properly charging it by doing this procedure.
Additionally, you may want to check this tips to maximize your tracker's battery.
Hope this helps.
Best Answer03-03-2017 11:58
03-03-2017 11:58
Thanks for the tips! I haven't had any issues with charging and battery life. At low battery my Blaze seems to take about 1 1/2 hours to charge which seems to be about right. And my battery life is about 5-6 days which also seems about right. 🙂 I was more curious what the original poster might consider to be "slow" for charging. I know the Blaze takes a bit longer than my One did to charge but it's also a more complicated device that likely has a larger battery so it seems normal.
