09-01-2017
06:38
05:02
AlejandraFitbit
09-01-2017
06:38
05:02
AlejandraFitbit
My Blaze after a full charge lasted at the lease 5 days. Then 3 days. Now I am lucky to make it through the day. Charge it before bed, so I will track sleep only to wake up and battery is 100% drained and charge it again the day. This is with all the perks turned off. No all day sync, no quick view, notifications turned off , music off. At the moment I have a black screen and noticed my iPhone is looking for it. If anyone has an idea of what the problem can be, please share.
Thank You,
Tammy
Best Answer09-01-2017 07:02
09-01-2017 07:02
Tammy contact customer services I found them extremely helpful😊
09-02-2017 11:39
09-02-2017 11:39
I have restarted and done everything suggested by this blog . My Blaze continues a battery drain within a day, along with incorrect information. Clock has been 3 hours off.
09-02-2017 12:14
09-02-2017 12:14
Mine had exactly the same issues i.e. Running down in a day plus incorrect time. Plus an added issue of the LED's on the rear were constantly extra bright and not flashing.
Contact customer services they were fantastic and responded straight away to resolve the issue😎
09-03-2017 05:05
09-03-2017 05:05
It's great to see you here @Tammy1105, @austin34 welcome to the Forums and @Davy1566 thanks for stopping by. I am glad to hear that you will be receiving a new tracker, at the moment of receiving it, follow these steps to set it up:
Now about the battery issue that you are having, I suggest taking a look at this post and follow the instructions provided there. After these steps, test your trackers.
Let me know the outcome. ![]()
09-08-2017 14:40
09-08-2017 14:40
Best Answer09-08-2017 14:45
09-08-2017 14:45
Best Answer09-08-2017 15:31
09-08-2017 15:31
Thanks........
Tammy1105 Blazes' Obit........
I have exhausted all ............. My Blaze has passed..........I am still wearing it. But it is time to say goodbye. Any suggestions??? Can only do some much. Thank everyone for your suggestions. But trying to keep my Blaze alive without being on Battery (life)-support is too stressful. I will miss my blaze friends. But you all must go on. I do want to thank everyone that has helped me with set up help.. and problems along the way. Very appreciated.
Sincerely, Tammy~![]()
Best Answer09-08-2017 16:17
09-08-2017 16:17
Mine too..............its dead!!!!!!!!!!!! NO REVIVING
Best Answer09-08-2017 16:31
09-08-2017 16:31
By the time you notice your time is off, your phone has already lost its connection to your tracker......battery is swiftly dying in silence............. ![]()
Best Answer09-08-2017 16:32
09-08-2017 16:32
I will give it a try.......Thank you Davy.......My Blaze is dead. I can no longer keep it going.
Tammy~
Best Answer09-09-2017 05:52
09-09-2017 05:52
Tammy if your Blaze is still within warranty you should definitely contact customer services.
I have a heart problem so I too was lost without my Blaze😫
I found customers services efficient and helpful...don't give up on fitbit just yet😫
Davy😎
09-11-2017 04:08
09-11-2017 04:08
Thanks for the information @Tammy1105 and @Davy1566 for the feedback.
As recommend to our friend, please keep an eye on your inbox for further instructions.
Keep me posted. ![]()
