Battery draining too fast
I have a Blaze for about 2 weeks. The battery is supposed to hold a 7 day charge. So far, it only hold 1 1/2 days. I have to charge it every other day. Is there anything I can do? I use it for tracking exercise and occasionally check time.
5 REPLIES 5
@Dianew53 It's great to see you in the Community! So sorry to hear that your Blaze's battery is not lasting as long as it should. Take a look at this help article which contains great tips that will help to save battery. If the problem persists, I recommend contacting our Customer Support team so they can investigate further and get you back on track.
Keep me posted on the outcome my friend and I'll be around! Smiley Happy
JuanJo | Community Moderator
Running with music makes you happy! Share Your Story
Hi
I am new to the community and getting used to using it so please excuse if this appears in the wrong area or has been covered else where.
I have had the Blaze for a little while now and had the same concerns over the battery life as I to got 1 day + of batterry life. I experimented with charging and heres what I found:
By charging thru the USB to wall plug, I got a very short run before having to re charge (1 day approx)
By charing from the computer USB port I got 5 to 7 days - dependant on use.
Hope this helps.
Thanks for the tip. I'll give it a try.
Sent from my iPhone
I charge mine through an Xbox One. It gets me 5-6 days on a charge.
Owns both an Alta and a Blaze. Crew Commissioner for the LSPD (Los Santos Poilce Crew) in Grand Theft Auto Online (Xbox One). CEO of 666 Industries (Grand Theft Auto Online). Addicted to Member Berries.
Welcome to the Community @NickW1@Dianew53 it's great to see you around, @Driver8666 thanks for stopping by. Woman Happy If your tracker's battery is not lasting, I recommend checking this post where our friend @AngelaMa is providing some good steps to follow. If those steps don't work, as @JuanJoFitbit mentioned, feel free to contact our support team. For a faster response you can contact them via phone or chat.
Let me know how it goes. Woman Wink
