01-24-2018
03:31
20:12
DavideFitbit
01-24-2018
03:31
20:12
DavideFitbit
I’ve had a Blaze for about 10 months. Last night put it on charge and this morning it was only half full when I woke up. Thought maybe I didn’t put it in the charger correctly but then when I took it out, it dropped to the red. Plugged it in and it shot up to 50% again not moving from there. Is the battery on it’s way out?
09:23
08:52
01-24-2018
09:23
08:52
Hi there @Dannyk77. Great to see you in the Fitbit Community Forums! 🙂
I'm sorry to hear that your battery seems to be draining faster than it should 😕
I can recommend putting it to charge and once it's fully charged, take it off the cradle and put it on. Sync it and use it as you would normally do. Make sure to sync it frequently after this so that the battery levels are recorded on the app logs and once the battery dies, let me know so that I can take a closer look and then we can move forward with other options to get you back on track.
I'll be looking forward for your reply!
