08-26-2017 11:30
08-26-2017 11:30
My Fitbit Blaze tracker is flashing red, telling me to charge the battery. The app still has the battery at medium. Why are the two different?
Best Answer08-27-2017 06:46
08-27-2017 06:46
The app only knows the battery level as it was when it last synced.
08-27-2017 07:12
08-27-2017 07:12
I manually synced it and it was still orange, while there charger was blinking red.
Best Answer08-27-2017 07:16
08-27-2017 07:16
hmm, if the sync doesn't get them on the same page then I'm confused
Best Answer08-27-2017 11:56 - edited 08-27-2017 11:57
Does the step count in the app match the step count on the tracier?
What about fitbit.com?
Best Answer08-27-2017 12:09
08-27-2017 12:09
I didn't check that. Have been dealing with a migraine all week. I will check it the next time it happens though.
