02-17-2017
14:05
04:16
AlejandraFitbit
02-17-2017
14:05
04:16
AlejandraFitbit
My battery is not charging.
it very slowly got to half charged overnight and as soon as I took it off charge, it went to flat again.
the green lights on back on are not flashing either
i have tried reset (left button and bottom right); I have tried shut down but it won't turn off
Best AnswerHello @nobatterycharge, does your tracker have the messahe http://fitbit.com/setup? There will not be a battery icon.
Is it setup?
A warm welcome to the Forums @nobatterycharge, @TanyaAdam and @Rich_Laue thanks for stopping by.
I would like to know if you keep having problems charging your trackers? If you do, I recommend checking this post where you will be able to find some tips to fix this inconvenience.
I hope this helps, let me know the outcome. ![]()
