03-26-2017 10:09
03-26-2017 10:09
I had charged my dead fitbit blaze this morning until it was fully charged. 5 hrs later, its dead again. I had no issues with the blaze until today as it normally lasts for over 3 days. What coudl be wro f
Best Answer03-26-2017 12:26
03-26-2017 12:26
What type of charger are you using? Should be UL certified charger. Has lower voltage. Or plug it into your computer.
Best Answer03-26-2017 16:39
03-26-2017 16:39
I was using the charger that came in the box and was plugged into my laptop to chage.
Best Answer03-26-2017 17:48
03-26-2017 17:48
I'm having a similar problem after installing the Firmware update on Thursday. The instructions for the update said it could take "up to 10 minutes," and mine took an hour. I charged it Friday overnight, then about 24 hours later, the battery was almost dead. I just re-charged it again this afternoon, so I have to wait and see how long it holds the charge this time. I charge it using the charger that came with my Blaze.
Best Answer03-27-2017 07:22
03-27-2017 07:22
Best Answer03-27-2017 07:23
03-27-2017 07:23
