Sorry @Paul62, battery is static, can't be swapped.
Best life from Blaze can be achieved by turning off quick view and all-day sync in settings (gray'd index card at top right of mobile app) The screen is quite bright and keeping it lit costs some battery life 😉
I've done it and enjoy 4-5 days charge.
Give it a shot. Welcome to forums.
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
I've had mine for a little over a year now and mine has started doing the same thing! It used to hold a charge for ~5 days but now I can't go 2 days without having to charge it. Bummed because that was one of the reasons I wanted a Blaze over the Apple Watch!
Welcome to the Community @Paul62, @heholder1 great to see you around and @wmchapman thanks for stopping by.
I would like to know if you keep having issues with your devices battery life? If you do, I recommend taking a look at this post and follow the instructions provided there. Keep in mind that after these steps you should test your trackers.
Let me know the outcome. ![]()
