06-21-2016 19:21
06-21-2016 19:21
Hello everybody.
I bought my Blaze yesterday.
What are the measures to achieve the longest battery use?
I mean to have Blaze working as long time as possible with one charge.
Best Answer06-23-2016 04:00
06-23-2016 04:00
I hope THESE ======= >
https://community.fitbit.com/t5/Blaze/Tips-to-maximize-the-battery-life-of-your-Blaze/m-p/1263819
help, Alex.
I've had a Blaze for about a month and easily get 4-5 days between re-charges.
However, I don't use notifications, don't use it to control music and don't have the unit set to all day sync.
06-23-2016 04:00
06-23-2016 04:00
help, Alex.
06-23-2016 17:52
06-23-2016 17:52
Thanks a lot. Now I know how to prolong FB battery life.
Best Answer06-23-2016 18:54
06-23-2016 18:54
I have everything turned on and get 4 days
Since it only takes a minutes to topup, why not charge it while taking a shower?
06-25-2016 09:48
06-25-2016 09:48
Hello @alex5908, @SunsetRunner and @Rich_Laue! Hope you are having a great day. 🙂 @alex5908 my personal advise is to charge the battery of your tracker only for the required time ( it can take up to 2 hours) also don't let your battery drain completely and if you are using a wall charger make sure it is UL certified. If someone has more tips to improve the battery life of the Blaze, please share so we can get the most out of our tracker!
Happy stepping! 🙂
It is health that is real wealth and not pieces of silver and gold! Share your story!
Best Answer06-25-2016 13:33
07-20-2016 13:12
07-20-2016 13:12
Best Answer07-20-2016 14:01
07-20-2016 14:01
I wait until my battery is low and then pop it on the charger while I'm at work. I sit down for work anyway, so it's not like I'd be missing out on steps or anything. I charge it about once very 4 days.
Best Answer07-21-2016 04:27
07-21-2016 04:27
Welcome to the Fitbit Community @dymndva! It's great to have you here. I have read some users charge it daily while showering and haven't heard of any malfunction caused to the tracker's battery due to this. Personally I charge it every 4 or 5 days as @Heather-S mentioned.
Let me know if you have any questions! 🙂
