07-31-2017 15:11
07-31-2017 15:11
Hi all
My Blaze is only 7 months old. I have only used it a few time. But have tried to use it more o we the last week.
I am lucky if I am getting 5 hours from a full charge. I have the latest firmware on the device. Can any help on how to fix the issue ?
Best Answer07-31-2017 23:40
07-31-2017 23:40
In fact it may be worse had the device fully charged. Went for a 30 minutes walk and the device was at 75% charge
Best Answer08-01-2017 16:45
08-01-2017 16:45
A warm welcome to the Community @Stuffedhaggis! I would like you to restart your Blaze and make sure you're properly charging it. Additionally, I've shared your post with Customer Support; they will provide further instructions.
Hope this helps! ![]()
Best Answer08-01-2017 17:40
08-01-2017 17:40
Hello,
I have a Blaze that is less than two weeks old and the battery will only last 1.5 days after a max charge. i have turned off the all day sync and that doesn't help. Can you tell me what else to try?
John
Best Answer08-03-2017 11:43
08-03-2017 11:43
A warm welcome to the Community @jherbst! I would like you to try restarting your Blaze and make sure you're properly charging your tracker.
Hope this helps.
Best Answer08-28-2017 14:14
08-28-2017 14:14
Thank you for your suggestion. i have tried restarting the tracker and fully charging it a few times. Unfortunately, the unit still only lasts a day and a half or two at the most. Do you have another suggestion?
Thanks for your continued help.
Best Answer08-28-2017 14:38
08-28-2017 14:38
Fitbit does have a warranty, and a support desk. They can dee what is happening inside the tracker.
Contact info found in the help site, or click on your picture above, or under help in the app.contact.fitbit.com
