I charged mine on Friday. It's still going with a Medium indicator on the watch, app and on my dashboard as of now.
I haven't really had issues with mine running out of battery faster than before...
You could try to restart your tracker by pressing and holding the left and lower right buttons for 10-15 seconds and after that, keep an eye on it and see if that makes any difference.
Let me know how it goes. Good to see you around guys @Driver8666 @madihak @shannie.chua
Best AnswerMine lasted a week before the update - seems similar now although I haven't been using it much.
Best AnswerI don't use the extras unless I want to. That's how I can get 5-6 days out of the battery. Even with all day sync on. I have the Bluetooth off on my phone unless I want to listen to music or sync the Blaze.
I agree with @Driver8666. I think that now that you can get more notifications, this could make the battery to last less.
For example, it used to last between 5-6 days before but now that I get whatsapp notifications, I would assume that the vibrations (wich are more frequent now due to the notifications) will drain the battery faster. I would recommend disabling notifications from apps that you don't really care about and only leave the most important.
Good to see you around @Teach3 @walt73
