10-30-2017 11:46
10-30-2017 11:46
After each recharge, it takes one to two days to sync Blaze with IPad device. Called customer service within 30 days of purchase; told to reset device to sync. Suffering with this option for 6 mos now. Enjoying device however the added feature of “reset to re sync” is maddening. After several calls and Tweets for assistance, I’m getting no where fast. Help pls.
Thx: loosing weight in frustration.
Best Answer11-01-2017 06:12
11-01-2017 06:12
A warm welcome to the Community @Only1damomma, thanks for troubleshooting this by yourself.
If your tracker is not syncing properly, I recommend taking a look at the Having trouble syncing? post and follow the instructions provided there. After these steps, your tracker should sync without an inconvenience.
Let me know the outcome. ![]()
