02-27-2016 21:31 - edited 02-27-2016 21:32
I have been testing the Blaze vs the Surge on my last two walks. The Blaze is not reading distance correctly using Connected GPS. Here are the detailed results from the last quite slow walk.
Unit Blaze Surge Notes
Time 41:50 41:42.22 I pressed the two starts and stops within 0.5 sec
Dist 2.59km 2.20km The 2.20 is accurate - on both walks the Flaze was well over
Avg Pace 16'07" 18'55" The surge is closer
Hrt Avg 86 80
Steps 2953 2920 The surge step counting is a little erratic
Elevation 36.57 36.57
My phone is a Samsung S5 running Android 5.0
03-08-2016 15:51
03-08-2016 15:51
I'm not teaching the theory of it all just trying to give a basic course without getting into a deep technical discussion about it all. I know all about triangulation and such as I worked on Radar, Tracking and Navigation all the other cool goodies that tell a Navy Carrier Battle Group where everyone is, was and need to go. I was just trying to keep it basic and illustrate possibly one explanation. Yes you are right that you need at least 4 for Triangulation as you stated.
On that note It's time to head for the gym you guys have at it. Good luck.
03-08-2016 17:39 - edited 03-08-2016 17:41
Great, so you probably know that triangulation is an inferior term to trilateration for this discussion ...
03-08-2016 23:48
03-08-2016 23:48
03-09-2016 06:50
03-09-2016 06:50
@DavS All my testing is done from starting the exercise from the Blaze, not the app. I wait until I see the gps connection on the blaze, then start the watch and Endomondo on my phone at the same time.
I did a 5k run this morning.
Both are using the same gps signal. There is a 0.1 mile difference between the blaze and endomondo. However, as you can see on the map, that difference came up at the start of the run and stayed constant the whole time. For some reason, there was a glitch on the blaze. Other than that glitch, I think accuracy is pretty good, at least for use with my phone. I have an original Nexus 5.
The current pace shown on the blaze seemed ok but not very precise. It's hard to validate because it's not stable at all on endomondo either. If my main goal is to have a very accurate current pace, maybe a phone gps won't cut it. I love the blaze and fitbit in general, but I'm not sure it's aimed at runners who want to improve their pace.
03-09-2016 08:30
03-09-2016 08:30
03-09-2016 08:47
03-09-2016 08:47
Regarding GPS errors, keep in mind that many phone apps will process the raw GPS, "smoothing" the data which (usually) results in a cleaner and more accurate track.
03-09-2016 08:50
03-09-2016 08:50
I just repeated the same walk this morning that I did yesterday, initiated from the "walk" exercise on the Blaze. I had increased my stride length by 8" to see if that had an impact on the distance reading. I made sure I had a good connection to my phone prior to starting, and today is a clear day. My Blaze ended up logging 0.73 miles (should be 0.98), so it is still coming up short on the distance even with the change in the stride length.
Later today I am going to repeat the walk but initiate it from the "run" exercise on the Blaze to see if that makes any difference. It is interesting that some people are getting shorted on distance while others have the Blaze showing increased distance. That is why I was curious to see if the stride played any part in the variability.
03-09-2016 09:25
03-09-2016 09:25
@DavS This is interesting and may point to an app-Blaze communication error rather than the Blaze only. I get a reliable 10+% over distance no matter the stride length and I get 10+% on a bike ride too.
So, I am running Android 5.0 on a Samsung S5. What phone/system are you running?
03-09-2016 09:28
03-09-2016 09:28
03-09-2016 09:38
03-09-2016 09:38
03-09-2016
09:48
18:35
MariamV
03-09-2016
09:48
18:35
MariamV
I have emailed Fitbit at https://contact.fitbit.com with this version/app error idea so I await any response.
I have also suggested someone from fitbit join in this thread to show everyone that they are not just ignoring the problem.
03-09-2016 10:29
03-09-2016 10:29
@MuzDownUnder Thanks for sending the email to support! I think it would be a great idea to have a fitbit employee join the thread. So far my Blaze is consistently showing about 25% less distance than actual when I initiate the exercise from the device. Maybe there is something wrong with my Blaze, but it seems as though enough people are having problems with this that they should be investigating this. I will probably email support as well once I have finished all the rest of the "test" walks I want to do.
03-09-2016 11:25
03-09-2016 11:25
Ok, so I just did the walk 2 more times. The first time, I initiated it from the Blaze in the "Run" exercise tile. Prior to this, I had only entered in a walking stride, since I'm still not at a point where I can run. I had updated the walking stride prior to this morning's walk to see if that made any difference in the distance measurement (it didn't). I thought that I should probably put something into the running stride, so I put in a number that was the same as the walking stride (currently at 3.3 feet after increeasing it this morning). I then went on the walk and got a distance of 0.92 miles (actual distance is 0.98 miles). This is considerably better than the 0.73 miles I got this morning.
Immediately after I completed the above walk, I stopped, initiated a walk from the Blaze using the "walk" tile and got the following:
While it is still off, it is better than the 0.73 from this morning. I'm not sure what any of this means. Did putting something into both the walking and running stride settings improve the readings? I may clear both of those out and try it again later this afternoon. All I can say for sure is that I get inconsistent readings when I initiate a walk from the Blaze compared to doing it from the fitbit app.
03-10-2016 09:50
03-10-2016 09:50
The reply I have from Fitbit is
"Thank you so much for letting us know about the details of the issue you're experiencing.
Rest assured that the issue has already been brought up with our product specialists and our engineers are hard at work in fixing the issue."
It would have been nice if they had told everyone here that they are even aware of a problem
03-10-2016 11:49
03-10-2016 11:49
@MuzDownUnder That kind of sounds like a canned response, but I hope they are taking it seriously and working on a solution.
I did another couple of walks today. For the first one, I wasn't getting a good connection between my Blaze and my phone, and it didn't end up using GPS data (at least I didn't get a route plot). I discovered that somehow my phone was set to "GPS Only" instead of "High Accuracy". I changed this setting and was able to get a good connection, so I did another walk. During both of the walks, I had SHealth running as well, and both walks gave me the same distance of 0.97 miles. My Blaze gave me distances of 0.8 miles (the one without route data) and 0.82 miles (seen below).
I am still getting somewhere between 15 and 20% low on distance measurements initiated by the Blaze, using the connected GPS. An interesting thing is that even though the two plots above should look identical (presumably using the same GPS signal), there are some differences. Maybe it's because SHealth is using thicker lines, but that is something I'll have to investigate.
03-22-2016 14:41
03-22-2016 14:41
Hi All
An update to all having similar problems. After a string of emails to Fitbit support (about 70% of which only got canned answers) we made small progress. Fitbit decided the Blaze must be faulty and sent me a replacement. This one has an identical problem. I tried the Blaze on another phone with a different operating system with exactly the same result.
Fitbit did admit they couldn't duplicate the GPS problem but that is as far as we have got.
What fitbit need to do is
1) Assign one member of the "fitbit support team" to a case. Every time I email I get a different person answering the email and it is obvious that they do not know any of the history. This is very frustrating.
2) Create some system where they can put me in touch with the development team so we can actually make progress on finding out what the problem is. I have eliminated the Blaze and the phone so I am only left with my location in the world or some other obscure issue. I am more than happy to work with the development team. If it is a location issue you need people in other locations to test for you.
3) Stop sending out the really annoying canned answers to emails that are trying to help. Not good PR fitbit.
@EmersonFitbit I hope you get this and can do something constructive with it.
I await a constructive reply.
MH
03-22-2016 14:53
03-22-2016 14:53
Fascinating threat. I saw this because I'm having the opposite problem. My Blaze is always 3% short on distances. My Surge was always spot on. There is a 3.00 track I did this weekend. One loop with my Surge, one loop with my Blaze connect to my iphone 6s.
Surge was 2.97 miles off by 1%. Blaze was 2.92% off by 3%. Every single walk I've taken with my Blaze has been short. Interesting that you guys are seeing longer distances...
03-23-2016 10:13
03-23-2016 10:13
03-26-2016 07:50
03-26-2016 07:50
I have had the opposite experience. I ran today and last weekend and the distance on my Fitbit Blaze was way short.
Last week
Blaze: 3.36mi
Actual: 3.82 mi
Today
Blaze: 2.3 mi
Actual: 3.1 mi
Anyone else having issues with the distance being short?
03-27-2016 17:18
03-27-2016 17:18
