I have had a number of issues lately. Anyone else experiencing these? I have had my blaze almost a year and a half.
1. Battery stays charged for different duration. Sometimes 5 days, sometimes only a day. I have read some of the other topics and ensured that it is being charged correctly.
2. Can't sync to my iPhone sometimes. I need to power off the fitbit and get force shut down the app. Sometimes I will have to re-pair the Bluetooth.
3. I don't receive texts or calls anymore even though the setting is turned on.
Thanks for any input or troubleshooting.
#3 is my current issue.
Actually, this is very annoying. I've done all the recommended "fixes" to no avail.
As far as the battery life goes, if I use it to track a walk or exercise, it does use more of the battery.
Not much help.
Best AnswerWell, I was just messing around on the app for my Android and I found a solution, for me, to the lack of notifications.
Seems the app NOW wants access to all contacts before it will send notifications to the Blaze. I just happened to select my device on the app and started going thru each setting. When I chose to "not allow access" the app actually said that if I do NOT allow access, I will not receive notifications.
I do not know if that will work for you, but I have resolved my issue, so far.
