01-06-2016
19:00
09:12
EmersonFitbit
01-06-2016
19:00
09:12
EmersonFitbit
I don't necessarily need the Blaze to be waterproof. I would like it if I could wear it when swimming (key word is swimming *not* diving) or even for a quick shower. Living in Seattle, if I'm biking there's a good chance its also raining. Sometimes no matter how fast you pedal you just can't outrun that cloud!
Every one of my Fitbit has had the standard blurb about the occasional splash but not recommended to be showered. If the seal is an issue can it be manufactured with an 'O' ring installed? I do understand that's an over simplified "solution" If the charging port prevents it to be water resistant, use some form of magnetic or "osmosis" charging so there's no exposed port. Again - over simplified. Will that cause the watch to be higher in cost? Personally, I'm okay with that. I paid over $200 for my Surge HR which I love but I can't modify any part of it. Having the option to swap out the band especially if its starting to look a bit haggard is worth it to me.
I think of all the improvements the clamoring hasn't changed much in the need for it to withstand water.
Moderator Edit: Title For Clarity
02-20-2016 10:51
02-20-2016 10:51
@bbarrera i mention the glud becauze i hsve seen msny reports of the Charge, Cgarge HR, and Surge bands having bubbles were thr vand gas seperated from the tracker.
Why is it seperating?
Ad for water resist as nce oc the Blsze, it is rated as 1ATM, the international stsndard for this rating is splash proof, and sble to withstand sn accidental spill in the water. Swimming may put to much force on it.
Best Answer02-29-2016 04:24
02-29-2016 04:24
After my charge HR took a dive in to the bathroom sink for less than 30 seconds and died i am not risking water going anywere near my blaze.
Best Answer03-02-2016 06:59
03-02-2016 06:59
For this reason, I had to choose Garmin vivoactive. It is similar price but water proof. However, Garmin's bluetooth sucks and it does not sync with the phone reliably.
Best Answer03-20-2016 04:13
03-20-2016 04:13
Best Answer03-28-2016 12:41
03-28-2016 12:41
My old flex lasted through two years worth of showers, the occasional swim and two Tough Mudders without a problem.
Best Answer07-09-2016 13:05
07-09-2016 13:05
My Casio Pathfinder watch, older tech than the Blaze, has an altimeter and barometer, yet is water resistant to 10 BAR (330 feet). I scuba dive with it. I don't think citing 'an altimeter' as a cause is really the cause. Perhaps the version chosen....
07-10-2016 08:32
07-10-2016 08:32
My husband has the Garmin which is waterproof to 300ft and has an altimeter. So I'm really not sure how that is true.
07-18-2016 13:41
07-18-2016 13:41
For what it's worth, I wear my Blaze when washing dishes, giving the kids baths, and I've worn it in the shower a couple times. I haven't experienced any issues with it getting wet yet.
Best Answer08-21-2016 14:08
08-21-2016 14:08
how do you fully seal it
Best Answer09-30-2016 10:46
09-30-2016 10:46
Best Answer05-30-2018 18:37
05-30-2018 18:37
I totally agree Fitbit is out to lunch on the water resistance for swimming there is no reason other than trying to skirt the issue by making them so cheap and stating water resistant to rain and splash...wow
