03-08-2017 23:15
03-08-2017 23:15
Hi all
I am a new Blaze customer and using Iphone 6S with all latest firmware and app too.
I want to ensure the Blaze works correctly when it needs to and at the same time want to preserve my iPhone battery life.
At present my settings are as follows - is there anything in my setting that may cause the Blaze to not work correctly when I need it to?
Default - Background app refresh - Turned off
Location services - set to 'While using'
Fitbit app settings:
- All day sync switched off
-Bluetooth sharing - on
- Media Library - on
-Background app Refresh - Greyed out due to have it off on my iOS setting.
-Cellular data - on
Basically, If I start a exercise, I want to Blaze to be able to connect to GPS and start working without have to fiddle with settings each time.
Thanks in advance
Paul
03-09-2017 04:06
03-09-2017 04:06
A warm welcome to the Community @tallpaul1213 and @WendyB thanks for stopping by.
If you want to preserve your phone's battery, you should use it as you do now since the app won't drain it, now if it your Blaze battery you can check the Tips to maximize the battery life of your Blaze post. About your exercise, you just need to select the exercise from your Blaze and the connection with your phone's GPS will start.
If you need anything else, let me know.
03-09-2017 00:38
03-09-2017 00:38
You should not have to fiddle with settings
Open the app then go to your Blaze locate the exercise you want and wait for it to locate your Phone. Sometimes it does take a couple times to connect. But most times it connects right off.
You can close the app after its found the phone
Wendy | CA | Moto G6 Android
03-09-2017 04:06
03-09-2017 04:06
