07-13-2018
23:33
08:13
AlejandraFitbit
07-13-2018
23:33
08:13
AlejandraFitbit
Hi,
I have had my Fitbit Blaze for about a year and a half now and for the past 3 days the battery life has not been lasting for more than 24 hours. I have checked all my settings but it's still runs out, it used to last up to 3 to 4 days any suggestions.
Thank you
07-14-2018 04:33
07-14-2018 04:33
This same thing has just started happening to me as well!
07-14-2018 05:58
07-14-2018 05:58
Mine is doing the same. Although, this last charge has lasted 48hrs....
07-14-2018 14:33
07-14-2018 14:33
I am only getting a two day charge. I have only had my Blaze for about 1 year. What is the company doing about it?
07-14-2018 14:47
07-14-2018 14:47
07-14-2018 15:09
07-14-2018 15:09
Within the last few days I’ve noticed that my battery only last about 4 hours. I don’t know what happened because it hasn’t gotten wet or anything and it was fine just a few weeks ago
07-14-2018 19:19
07-14-2018 19:19
My Fitbit Blaze battery is dead 2 months after the warranty is finished.
The customer support and the supervisor says they could not do anything but offer me 50% discount on next device. What illogical suggestion. why would I buy new band each year after knowing the your devices don’t last more than the warranty. It seems that the devices don’t last more than the warranty.
07-15-2018 00:27
07-15-2018 00:27
07-15-2018 00:57
07-15-2018 00:57
My battery drained suddenly yesterday too. It also coincided with my app being updated and no longer tracks my heart rate on auto, even after restarting. My blaze is 15 months old and has worked perfectly up until now. I’m hoping it’s all related to the latest app upgrade and will be rectified with the next upgrade.
07-15-2018 01:03
07-15-2018 01:03
07-15-2018 05:09
07-15-2018 05:09
07-16-2018 13:49
07-16-2018 13:49
Very same problem, is there a solution?
07-16-2018 13:53
07-16-2018 13:53
07-16-2018 15:18
07-16-2018 15:18
07-16-2018 15:43
07-16-2018 15:43
I have had mine for 6 months and I get about 24 hours out of a charge. I expect from these posts that this will get worse.
07-16-2018 16:51
07-16-2018 16:51
07-16-2018 20:32
07-16-2018 20:32
You are very lucky. I called and e-mailed that my Fitbit was not keeping a charge for long. I have had it for a year and a half. This is my 4th Fitbit since 2012. I started with the little one that clipped on your belt and worked up to the Blaze. I wear my Fitbit all day long except when I charge it. I take very good care of it and do not have as much as a scratch on it. I am now charging my Blaze 4 times a day.
After going back and forth with Fitbit customer service (I requested a new battery) I was offered a discount of 25% off a new Fitbit.
I think what I am most upset about, is that I will lose about 5 years of history when I purchase my new fitness tracker. I told them I would not be using their 25% discount because I am going to purchase another brand. They know that they have a problem and have decided not to back up their product as far as I can see.
07-17-2018 05:44
07-17-2018 05:44
Thank you for the reply. This is my second Fitbit and I am very disappointed. The first was a Charge HR. It literally fell apart. I like what the products do, but I do not know if I can stay with such a poor design. Do you have any suggestions for replacement? Thanks again.
07-17-2018 06:42
07-17-2018 06:42
07-17-2018 09:44
07-17-2018 09:44
Hi Nishant!
Thanks so much for the suggestion!
I will look into Garmin when I get home from vacation.
Thanks,
Mina
