08-23-2019
13:39
11:21
08-23-2019
13:39
11:21
Is there any solution for this . Very annoying that I have to carry a charger to remove tracker quite often. Not sure what the issue is
Welcome to the Community Forums, @SaiIndra. I'm sorry for the late response. I totally understand how you feel. Thanks for the steps you've tried in order to keep your Blaze charged.
Please take a look at the help article Can I extend my Fitbit device's battery life? and follow the tips and recommendations provided there.
We recommend to charge your trackers via the USB port over a wall adapter. However, it is also possible to charge your Fitbit tracker with a UL certified wall adapter. What may actually cause damage to the tracker's battery (either on a computer or a wall adapter) is the charging time, which if excessive over time may damage the battery and therefore cause quick battery drain or prevent the tracker from charging at all.
Tips to best charge Fitbit trackers are:
For charging purposes, your charging cable can be plugged into any USB power source, including but not limited to:
Give this a go and let me know the outcome, I'll be around.
