Blaze is not syncing properly after traveling
IT is been a week since I arrive from vacation and my blaze has not sync the my current time, do you know how to do it!! I tried sync but IT does not work!!!
1 REPLY 1
Welcome to the Community Forums, @Viknilismo. I'm sorry for the late response. Thanks for already trying to sync you Blaze to correct the time.
To correct the time on your Blaze, please try the following steps:
  1. On your Fitbit app or Fitbit.com Dashboard online, change your Country settings to a different country and change your timezone to the desired timezone.
  2. Save changes and then Sync.
  3. Change your Country setting back to your actual Country (e.g United States).
  4. Save Changes and then Resync tracker.
When traveling, keep in mind the following information:
  • Most trackers store up to 7 days of detailed minute-by-minute data. If you wait longer than 7 days before syncing, you may only see the most recent week's detailed data.
  • Summary data (calories, distance, steps, and floors) will be stored for 30 days. If your tracker measures heart rate, summary heart rate data will be stored as well.
You can designate one time zone as "home base", and only sync while in that time zone (as has been mentioned, the tracker can hold a week's worth of data.) This would ensure that there are 24 hours in a day, though the times on travelling workouts will be off, but the data will be consistent.
Let me know if there's anything else I may do to assist you with.
