I had a similar issue a while back... I swapped the charging base with my better half's and it worked a charm on her's - currently sorting out a replacement with Fitbit support (fbs) (was in the warranty date) if you got another base give that a go, if not might be worth speaking to fbs and they can hopefully send you a replacement - good luck 🙂
06:09
10:14
06-25-2017
06:09
10:14
Great to see you around @Nicole_danielle and @finchi82 thanks for stopping by.
If you are having problems with your Blaze battery life, I recommend taking a look at this post and follow the instructions provided there.
I hope this helps, let me know how it goes. ![]()
