Hi, @Katet1979, unfortunately the battery on the Blaze cannot be replaced.
Here are some tips on how to maximise battery life.
Also, generally speaking, charging little and often, is good practice -- for example each day while you are taking a shower or in the evening when you are reading or watching televison so not likely to be taking too many steps.
Hi, @Katet1979, all rechargeable batteries have a limited number of charge cycles and battery life will be shortened if they are allowed to discharge completely (go flat) very often.
Depending on how old your Blaze is, if you have checked through the battery saving tips I shared with you above, you may want to get in touch with Fitbit Customer Support on contact.fitbit.com. They will be able to take a closer look.
