Blaze clock display setting
Anyone have knowledge of custom display views for the home/clock screen. I have tested out the standard ones in the settings section but none seem to be ideal for me.
Thanks in advance
1 REPLY 1
Hey @timbain, it's great to see you around.
Could you please be more specific about the issue you are experiencing? You want to be able to customize the Blaze clock faces? If this is the case, this isn't possible. I recommend visiting our feature suggestions and share your ideas.
See you later. Robot Happy
